Meziere Install Problem? Opinion Needed
Any ideas?
that way when the ignition is on the ewp is on....
Do you have a multimeter? You might need to do some investigating to make sure it is your problem...for starters, leave it sitting for a few days with the fuse removed for the water pump. If it is still draining, you'll need to look elsewhere. Otherwise, it is a problem with your wiring.
Appreciate the input, am I right or wrong in my thinking?
