qtp Y
Old Sep 3, 2007 | 05:36 PM
darkside98's Avatar
Default qtp Y
i have head a lot of bad things about the y fitment, has anyone had the qtp ORY fit well?? or does it really suck as bad as i hear it does??
Old Sep 4, 2007 | 09:53 AM
MISERICORDIA's Avatar
Yeah mine was a pain to get in. Took some hammering. Now that it is in there everything seems fine. Clearance doesn't seem to be worse than others.
Old Sep 4, 2007 | 05:21 PM
radz282003's Avatar
The best thing I did to cure my Y-pipe whoas was to remove the drivers side cat' from QTPs location and move a smaller replacement right off of the collector. Then, run a 3" U-bend (or 45*) pipe to the joint left by the original pipe and weld it all up. After a little cutting on some sheetmetal, I have no regrets. It fits as good as any 3" Y-pipe could, and has a merge collector.
JMHO. Good luck.
