PCV Delete on 02 car
Old Sep 3, 2007 | 06:23 PM
AutomagicLS1's Avatar
Default PCV Delete on 02 car
I want to delete my pcv system and run a breather. What do I need to plug both valve covers and the thing on the intake?
Old Sep 3, 2007 | 11:27 PM
XpEdItIoUs's Avatar
TTT I want to know to.
Old Sep 4, 2007 | 01:15 AM
bczee's Avatar
You can use rubber plugs and/or caps, or what ever you find to fit on the old fittings on the valve covers and the T/B, just as long as they seal. You can then run a breather on the oil filler cap and/or one the back of the driver side valve cover, where the PCV fitting is.
There are some good reason to kept the PCV system, one it to keep neg pressure in the crank case, which will help seal the piston rings.
There are many debate on running breathers and no PCV system or a PCV with a Catch can, both have there pros and cons. What are your reason for going your stated route?
