Spark Plug Wire Swap
Old May 30, 2003 | 06:33 PM
Ferocity02's Avatar
Default Spark Plug Wire Swap
When replacing the spark plug wires with Taylor "409" wires, do you have to re-use the the stock metal tube and spring that is around the wire down by the the headers? I noticed that the ends of the new wires do not fit into these cylinders. Do I need to get something else to protect them from the heat? Thanks
Old May 30, 2003 | 06:56 PM
Predator's Avatar
Default Re: Spark Plug Wire Swap
No, those are just for the stock wires.
Old May 30, 2003 | 06:59 PM
Predator's Avatar
Let me add that I've had the same Taylor wires for over a year with no heat issues at all, even with headers. Just plug 'em in, as is, and you're all set.
Old May 30, 2003 | 07:05 PM
Argon Z's Avatar
yes just plug them in and use some of the supplied electric silicone crap on the conducting points.
Old May 30, 2003 | 08:48 PM
Ferocity02's Avatar
Oh, I put that silicon stuff on the contacts? Wasn't sure
Old May 30, 2003 | 09:25 PM
Ferocity02's Avatar
Oh, and how do I gain access to pretty much every wire on the passenger side of the engine
Old May 30, 2003 | 09:53 PM
muscleSS00's Avatar
good luck I cut the hell of my self changing my plugs, just getting the wires off!
