Do Not Epoxy Your Tb
Old Sep 15, 2007 | 04:36 PM
schultzsj's Avatar
Believe it or not, I used large, aluminum knitting needles from Walmart (maybe 3/8" Dia?). I cut a chunk out of them like a straw to keep the air passsages open and then used the putty-style epoxy. I have had this set-up for 2-3 years without problems.
Steve
Old Sep 15, 2007 | 04:54 PM
brad8266's Avatar
The epoxy in my old ported stock TB stayed in there solidly and didnt throw codes for years. Just becasue yours is screwed up and didnt get done right doesnt mean we all shouldnt do it.
Old Dec 11, 2007 | 12:02 PM
Bad Blue WS6's Avatar
looks better without it anyways...
Old Dec 11, 2007 | 01:03 PM
bigdsz's Avatar
Shaner did mine ~6 years ago, at least 60,000 miles on it, no issues.
Old Dec 11, 2007 | 03:37 PM
Giddswat's Avatar
^^Thats good to hear!
Old Dec 11, 2007 | 03:51 PM
Steve Bryant's Avatar
LS1 Tech Veteran
Does anyone know of a documented case or two as to how much the HP/Torque changed before and after porting a throttle body?
Thanks,
Steve
Old Dec 20, 2007 | 09:43 AM
z-ya's Avatar
I used k&s 3/8 brass tube for my big hole and 1/4 for the other worked pefect and picked
up flow on my bench.
Old Dec 20, 2007 | 09:54 AM
andrew69_04's Avatar
i just had a big problem with those stupid codes last week on a 2001 silverado with a 5.3 turned out it was a weak fuelpump. did you epoxy your pump? lol j/j
Old Dec 23, 2007 | 09:45 PM
6-Speed Terror's Avatar
i have had mine for about 2 yrs with no problem i would get 250 miles per tank city with the m6 226 patriot cam now with a4 and stall and ms4 i get 200 i thought i was doin good thats doin a couple wot runs for a 1st to 2nd shift.
Old Dec 23, 2007 | 10:26 PM
Gregg 00SS's Avatar
I'd jump for joy if I got 200 miles per tank of gas, lol.
Old Dec 23, 2007 | 11:03 PM
TWS's Avatar
TWS
Have done two home port/polish/epoxy jobs on stock TB's with zero problems. Avoid the pitfalls that some other members have pointed out here, and I really don't see a downside.
Old Dec 23, 2007 | 11:14 PM
  #32
Tainted's Avatar
not to be a total dick but. if you know hoe to do it correctly, and many MANY TB porters did and still do this without problems, I know I enver have. if you correctly fill in the area, clean and prep the surface etc its nothing, if you dont well then. here we go with your thread
Old Dec 25, 2007 | 11:25 AM
  #33
Ragtop 99's Avatar
Yes, there were dyno tests years ago. Consistently people saw at least 5HP and 8 - 12 was the typical range depending upon other mods.
Old Dec 25, 2007 | 11:41 AM
  #34
mellowyellow's Avatar
I have back to back dyno graphs with a 6 rwhp and 4 rwtq gain.. The real increase is in the throttle response... I also have a Shaner T/B with epoxy and brass tubes in the air holes for years now... It's the best way to do it , it does'nt hit that wall so to speak when air enters and smoothes out the air path...
Old Dec 25, 2007 | 11:54 AM
  #35
socmguy's Avatar
Restricted User
I've ported over 20TBs w/ epoxy. I will admit, I have had trouble with 1 or 2 because of the reasons stated above but as long as you know what you're doing your IAC will work fine and get plenty of air. Your pcv return will be just fine, but the IAC is the most important.
Old Dec 25, 2007 | 08:31 PM
  #36
ERIK@MASPORT's Avatar
Closed Sponsor Account
Originally Posted by 02 Silver SS
Just wanted everyone to know NOT to put epoxy on your TB (where the vacuum hose gets air and the sensor) THE REASON NOT TO IS that the air will not flow right and will set off your SES light and throw codes P0171 and P0174 – running too lien on both banks… and like me you will get crappy gas mileage (200 miles per tank *with grandma shifting and driving*)
HAHA
I WISH I got that mileage
