Question on fitting Cats - HELP!!
I ask because I've got gutted 01-02 cats and the passenger side doesn't clear the floorboard and I wasn't sure if the manifold design gets it past the floor board or if GM actually reshaped the floorboard in 01-02.
Thanks!
As for them hitting the floor, no GM did not remake the floor for 01-02. Maybe you need the "BFH" mod.
That was my thinking too, so I orded a set of '01 manifolds, hopefully that will do the trick. I here there about as good as shorties and just couldn't see spending the some amount on shorties as I would to get longtubes. F'in california blows. I guess I'll run the 01' manis and gutted cats and swap my stock manis and cats back on for smog every two years. Then longtubes when I move.
Thanks!
