throttle body
Old Jun 1, 2003 | 10:35 PM
RAMnGO's Avatar
Default throttle body
ok time for thinking.. i have read somewhere on here looks like that most people say use a ported throttle body vs bbk's bigger throttle body. I am wondering though which is better ported throttle body on stock ls6 intake or a bbk body with an aluminum ported ls6 intake?? also would the aluminum intake create more heat then the stock ls6 intake?
Old Jun 1, 2003 | 10:37 PM
BIGBOS's Avatar
Default Re: throttle body
Unless you are using a supercharger or have a big cubes motor I wouldn't go with the BBK, its a waste, even with my forged internals F.I. motor, I'm going to be using the stock ported TB
Old Jun 1, 2003 | 11:00 PM
2001CamaroGuy's Avatar
stock ported on an LS6......BUT....not because the stock ported is better than the BBK....
The only reason I say this is the aluminum LS6 intake it the wrong way to go. It will get a lot of heat soak yet most people don't get much imporvement over the factory LS6 intake.
The way I would go (and did go) is with the BBK and the factory LS6 intake. I like the BBK a lot!
Chris
