90mm bellow? Guys using FAST 90mm intake please help!
Old Sep 18, 2007 | 03:52 PM
dfreeman2386's Avatar
Default 90mm bellow? Guys using FAST 90mm intake please help!
I just ordered a FAST 90/90 combo and I am now looking for a bellow. I can not find one anywhere. I was told that an SLP smooth bellow with the bubble in the middle would work. What are some of you guys using who has this same combo?
Old Sep 18, 2007 | 03:55 PM
AlexLS6's Avatar
SLP work fine for me
Old Sep 18, 2007 | 04:13 PM
TheLS1Kid's Avatar
I have a K&N FIPK with my FAST 90.
Old Sep 18, 2007 | 04:59 PM
SSwt00SS's Avatar
SLP Bellow worked fine for me as well...
just put it in some warm water and that will be enough to loosen it up to fit over the TB...
Old Sep 18, 2007 | 08:05 PM
INMY01TA's Avatar
I use the stock bellows on my FAST 90.
Old Sep 18, 2007 | 09:33 PM
Thule's Avatar
whe installed it on two cars.. just get some custom silicone hose and make it your selfs, its no problem, took us few minutes in two cars,
Old Sep 18, 2007 | 10:39 PM
ophee's Avatar
SLP's smooth bellow worked just fine... it also gave me better clearance for my clear lid... the arch helps.
Old Sep 19, 2007 | 01:15 AM
99DWPTA's Avatar
slp here
Old Sep 19, 2007 | 09:40 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
Stock bellows here.
Old Sep 19, 2007 | 11:43 AM
brad8266's Avatar
I got a bellow from an company called intakehoses, its a 4x6 coupler. Im mafless though.
Old Sep 19, 2007 | 05:54 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
I'm using the stocker as well
Old Sep 19, 2007 | 08:27 PM
DirtyJohn's Avatar
High temp silicone (one word) dot com
Not a vendor.
I got the 4" x 12" 3 ply and cut to fit, I am also mafless.
You will likely also need something to close the gap between the bellows and the lid snout, I used weather stripping from home depot.
Old Sep 19, 2007 | 09:20 PM
Thule's Avatar
that engine bay is HOT!!
SD?
Old Sep 19, 2007 | 10:35 PM
slow67's Avatar
Gingervitis Addict
Not a vendor.
I got a piece of 4"x6" silicone hose from a local hose supplier.....about $10
I used the piece of rubber that is made for the lid to maf connection.
Old Sep 19, 2007 | 10:51 PM
red_ryderSS's Avatar
Slp bellow works just fine here
Old Sep 20, 2007 | 04:18 PM
marv's Avatar
SLP worked good for me.
Actually used two of them. Second one was cut down in length to go from the lid to the MAF.
Good luck.
Old Sep 20, 2007 | 08:37 PM
Andros's Avatar
SLP holding up since last year
Old Sep 20, 2007 | 09:16 PM
deejaydaze's Avatar
Is that thing kinda pinched?
Old Sep 21, 2007 | 03:02 AM
junior28570's Avatar
^^ the SLP is fat in the middle so, that might have something to do with the way it looks being stretched on the TB.
