TSP Catted Y Pipe - Fit Issues / Installation Tips?
The passenger side seemed okay, but the cat on the drivers side was hard against the fuel lines (probably not good, lol!), and the single pipe that ties into the catback wasn't even close to being tucked up near the driveshaft to clear my torque arm mount / tunnel brace (the torque arm mount is clearanced for LT header applications and the ORY didn't have any clearane issues her or anywhere else). I deburred all the edges and lubricated the tube ends so they would rotate against one and other as I tried to fit it up, and I couldn't get it even close to fitting properly.
Unless someone has some suggestions, I'm contemplating selling this set up and looking into some Random Technology Cats to splice into my current Y pipe (that fits perfectly), or taking the pieces to a muffler shop and tell them to install / fabricate or whatever is neded to mount those cats on my car!
Anyone have a similar experience or any advice...?
Did you have the y-pipe assembled when to tried to install it? Is it not slipping over your header collectors? How far off is the y-pipe tubes from sliping over collectors?
As far as your cat-back hangin low when you connect the tsp y, you may have to cut some off of I-pipe so it will tuck up. It will droop until you push it up and tighten it.
Yesterday I stopped in a local exhaust shop that does custom work, and as I explained my problem he started smiling, so I responded with "So you've heard this kind of story before...?" and he said it happens all the time. He said he has to rebend and tweak pipes to get them to fit right because each car is just a little bit different and they all fit better if they are custom bent to that specific vehicle so that's what I plan to do on Thursday. No way can I stand having an exhaust banging against or sitting hard on the body and resonating sound throughout the entire car!
