alternate y pipe
Old Sep 24, 2007 | 07:43 PM
hokie00 TA's Avatar
Default alternate y pipe for pacesetters
ive got pacesetter headers and there y and they pipe sucks, if you get under the car when it is running and listen to the y pipe right at the merge it sounds like crap and then when you go down the road it sounds even worse and its coming from the same place as i listen to when its just idling. does it has something to do with the y or what i dont think it is leaking because i dont hear any ticking or feel anything coming outta the pipe where it is welded. and it bangs the floor under hard acceleration already took it to an exhaust and they bent the pipe away from the floorboard and it still hits. what can i do to reamedy all the problems.
Old Sep 25, 2007 | 04:17 AM
hokie00 TA's Avatar
nobody???
Old Sep 25, 2007 | 04:35 AM
SMALLBLOCKHERO's Avatar
ive read a couple complaints about the fitment before. not much you can do....it appears you already did more then most guys by tryng to fix it instead of sending it back.
