Water Pump Changing Time?
Old Jun 4, 2003 | 11:27 PM
Onyx Z's Avatar
Default Water Pump Changing Time?
About how long does it take to change a water pump in a LS1? I'm thinking about doing it when I get off of work at 7:00. Only about an hour of sunlight left after that (need a droplight).
Thanks
Ryan
Old Jun 5, 2003 | 08:24 AM
kp's Avatar
kp
Default Re: Water Pump Changing Time?
its easy to get the pump off a 98 but if it has the original gasket you will be doing some swearing at GM why they used a paper gasket there - they are a pain to scrape off. Other then that its a super easy job.
