TV cable/throttle cable bracket
Old Sep 30, 2007 | 05:21 PM
LS1MCSS's Avatar
Default TV cable/throttle cable bracket
If you are going to use a 200-4R or a 700R4, you will run into the same problem I did. A bracket for the throttle cable and TV cable has to be hand made if you run an aftermarket intake and 90MM throttle body. It took me about three hours to get this built the way I wanted it, but it will work good and the TV cable hookup has the correct geometry.
Old Mar 10, 2011 | 08:01 AM
rdkonkel's Avatar
Default tv cable
Looks nice, have you found any alternatives to the lokar cable, I am getting to the point of installing and need any advice you can offer.
Old Mar 10, 2011 | 05:24 PM
cacmanjr's Avatar
Default TV Cable
Bow Tie Overdrives makes a kit for the early small cam throttle bodies. I have that system on my current engine, but I will want to go to a fast and a bigger throttle body for my new set up. streetandperformance.com makes a weld on adapter for the lokar cable. It would be ideal to figure out how to run the tv cable from the accelerator pedal. Then you would never have to worry about changing throttle bodies or a bracket to hold the cable ever again. I had the kickdown cable on my old TH350 set up that way.
Old Mar 10, 2011 | 05:29 PM
Tobias05's Avatar
Originally Posted by cacmanjr
Bow Tie Overdrives makes a kit...
TV made EZ FTW. Running their 4150 system on my 87. Top quality, great kickdowns. Easy install.
Old Aug 19, 2020 | 05:27 PM
Lump1's Avatar
Default I'm in desperate need of this bracket setup if you cou
Please help me if u can I need this bracket asap
Old Aug 19, 2020 | 11:34 PM
You're not too observant. See the post right above yours. The one from many years ago.
