Which catback system to get (on a limited budget)
Another option is to make a custom catback using a 3" dynomax ipipe and over the axle pipe. Check the link for more info. http://www.dynomax.com/documents/pas...ral_motors.pdf
The pipes are available from summit for $100. Then you can pick out a muffler of your choice. This catback will cost less than $200. If you dont mind having a single tip on the drivers side, its a good way to go.
Loudmouth ROCKS! Can't wait to get Hooker LT/Carsound cats next month
There are a number of choices in the under $400 range and all of them will have good or bad points depending upon who owns them.
With that said, I have the LoudMouth and I really like it. It sounds great, gave me a some good increased SOTP performance, it looks good and it was cheap. I have no problems with ground clearance and the sound is great even though I have an automatic.
My vote goes for the Loudmouth.
The Hooker gets the best posts from what I have seen, and the price is right.
The LM is okay, but if you ever decide to run without cats, and worse yet get headers, most folks start to hate them.
The Magnaflow sounds like the Hooker to me, but costs alot more.
Now to complicate things...
The stock exhaust is 2.75" mandrel bent stainless. Most cat-backs charge you a ton more $$$, and yet the pipe is only .25" larger. It's all marketing hype, what they don't want you to know is that just getting the muffler gives you the same power increase for much less, and of course you get the sound you want too.
Just a thought.
Dave
that makes me insist that you hear this exhaust before you buy anything!!!
i will be buying one very soon
