Bad idle after installing Ported TB
Old Sep 30, 2007 | 08:12 PM
mikenews's Avatar
Default Bad idle after installing Ported TB
Hey guys I bought a throttle body from my friends 2000 z28. I have a 98 z28. I ported it and then I switched the throttle shaft over and used all of his sensors. It runs great besides it idles around 500 rpm. My dash say 650 rpm, but my scanner say 460-500rpm. I did the reset with the unplug tps key turn on already. Should I mess with the low idle screw?
Old Sep 30, 2007 | 08:13 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Yes, it is probably straight up and down. I would tweak it just a bit. Don't drill out the tb hole though on the blade.
Old Sep 30, 2007 | 09:17 PM
mikenews's Avatar
Got it thanks! I measured my screw on old tb it stuck up .080". The one I put on was .052". Adjusted screw up and .084" and BINGO!! Perfect!
Old Sep 30, 2007 | 11:13 PM
PierreLS1's Avatar
sweet ill tell my friend he is having the same issues
Old Oct 1, 2007 | 06:33 AM
socmguy's Avatar
Restricted User
Nicely done boys. I love reading threads like this!
