LT Headers
Old Oct 19, 2007 | 11:17 AM
angelR's Avatar
I installed my lt's from below with about 3' of height... used a lift. But then again that was into my rx7 Oh and it took less than 20 minutes!
Old Oct 19, 2007 | 12:03 PM
radz282003's Avatar
I believe the SLPs may require you to drop the K-member to install, although you might get lucky.
It may be worth checking whether-or-not loosening the bolts for the tranny crossmember and shifting it right or left will help with clearance issues. I've read that doing that helps a bit sometimes.
Good luck.
