Just got a ls6 intake and..
Old Oct 7, 2007 | 05:49 PM
ShortChevy's Avatar
Default Just got a ls6 intake and..
As the title states I just got a ls6 intake and had a question. Do I have to swap over to the coolant lines a plugs. I thought there was a way around this but I'm not sure. I searched but could only find part numbers for these parts. Not sure if I absolutly need them or not.
Old Oct 7, 2007 | 05:52 PM
DaveX's Avatar
The bottom of the manifold won't clear your factory coolant pipes. So you can swap them out for the style that just goes across the front with plugs in the back, or modify the bottom of the manifold to clear your existing pipes.
Old Oct 7, 2007 | 06:05 PM
ShortChevy's Avatar
From what I have read you just grind the ribs out of the bottem correct?
Old Oct 7, 2007 | 06:20 PM
cabech984's Avatar
Yep grind the ribs!!
Old Oct 8, 2007 | 09:00 AM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
Or you can carefully flatten out the coolant lines
