tires rubbing
Old Oct 9, 2007 | 02:52 AM
diablo078's Avatar
Default tires rubbing
ever since i put the new rims and tires, on the rear the tires are rubbing against the body. there only 295/35/18 and know people the are running 305/30/18 and they have no problem. should i get an adjustable panhard bar instead of the nonadjustable that i have right now?
Old Oct 9, 2007 | 03:44 AM
discostu's Avatar
an adj panhard bar will not solve this problem if both sides are rubing.
i would check for proper rims specs and make sure the rims have the proper backspacing
Old Oct 9, 2007 | 10:21 AM
djsanchez2's Avatar
^^ Check the specs. I run 315's w/ no problems. Still don't have adj. PHB either.
Old Oct 9, 2007 | 11:29 AM
diablo078's Avatar
well it only rubs on the driver side when turning hard to the right.
Old Oct 9, 2007 | 11:34 AM
smg267's Avatar
Search for BFH mod. "Big ****** Hammer!!!" You basically need to pull your wheel off check to see where it is rubbing and beat the inside of the fender wall in. Your gonna have to take it in a little bit. Once your done get the under body rubberized spray from an auto store and fix the areas that chipped off. It is easy!! I had to do it a couple times before I got my 315's to fit. Try the wheels section too!
