V-Plus Volt Booster
Old Oct 9, 2007 | 05:39 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
Default V-Plus Volt Booster
Anyone using this? Is it good? Bad? Yay? Nay? I've got a tune on my car with my diablo tuner. Will it screw stuff up? Any info much appriciated!!!
Thanks
-Charlie
Old Oct 15, 2007 | 04:31 PM
anyone using this????
Old Oct 15, 2007 | 05:36 PM
BLK02TA's Avatar
For anyone who doesn't know what it is:
http://www.ls1speed.com/cont.cfm?cid=C0000096
Caspers
V-Plus Volt Booster
Your alternator is designed to put out a specific voltage, generally 13.8 volts. The only problem is when there's a greater demand on the electrical system, such as a WOT blast, the alternator falls a little short. The V-Plus is designed to overcome voltage taper at WOT by stepping up the alternator voltage 2.2v. at 70% throttle. Result? More power to your fuel pump and ignition system. Unit plugs in, with no wires to cut or tap into. Includes hardware.
Old Oct 16, 2007 | 10:17 AM
EvoWake's Avatar
I'm curious about this as well... anyone?
Old Oct 16, 2007 | 10:25 AM
01Z28M6's Avatar
I'm using it on both my cars. It works as advertised. Both cars boost to 14+ volts at 80% throttle. I have verified this with my scanmasters in both cars. The lights go up on the dash et al. As for adverse effects, I don't run my car at 80% throttle for extended periods of time so I don't think 2.2 volts extra is hurting a thing and I'm sure my fuel pump says thanks for the nourishment....
Old Oct 16, 2007 | 06:44 PM
1-10 (10 being great) How would you recommend this to others? Has it tripped the SES light?
Old Oct 16, 2007 | 06:47 PM
618HAWK's Avatar
Works great no problems, Nor SES light.
Old Oct 17, 2007 | 04:24 PM
okay then i'm bought!
Old Oct 18, 2007 | 05:49 AM
01Z28M6's Avatar
There's nothing about it that would be detected by the pcm. When your battery is very low the alternator puts out extra current. I suspect the volt booster circuit tells the alternator that the battery is low and this is triggered by the signal voltage from the TPS - 80% to 100% throttle.
As for recommending it; I would for those who need all the fuel pressure available for boosted or nitrous cars and for ppl who simply want another performance item. I rate it at 8 because it does add one more part where something can go wrong and it doesn't really bolt or fasten anywhere. I have mine zip tied to whatever is convenient. BTW, I also have hotwire kits and external booster pumps so the Volt booster just augments the rest of that modification. When I think about it, I have spent almost $400 per car just to make sure there's good fuel pressure for the rare, rare times I'm using the nitrous - not far from the price of a basic n2o kit.
Old Oct 18, 2007 | 08:29 AM
Justa Z's Avatar
i have a used one $50 shipped, i use a accufab tb now and it wont hook up any more It worked great for me when you mash it you headlights get brighter instead of dim
Old Oct 18, 2007 | 09:39 AM
01Z28M6's Avatar
somebody is going to save $30 to $40....
Old Oct 18, 2007 | 01:52 PM
EvoWake's Avatar
Is there any significant reason to have this though? i don't expect it to cut your e/t down at all and i don't care if my headlights get brighter. Will my car get a little extra kick at WOT or am I misunderstanding this thing?
Old Oct 19, 2007 | 09:20 AM
01Z28M6's Avatar
Yes you are misunderstanding. The added voltage is fuel supply insurance and only for performance to that regard. If you are making less than 350 hp I wouldn't bother with it.
Old Oct 19, 2007 | 03:49 PM
SS101's Avatar
i would say that it would make you more consistant rather than faster. a more powerful, more stable current will not only ensure your fuel supply is adequate, it will also keep your vital sensors (MAF, IAT, TPS, O2s etc) at peak efficienty when you need it most. more efficiency = less varience in readings = more consistant ETs
Old Oct 21, 2007 | 01:19 PM
So should i bother? I'm making 353rwhp/370rwtq before i sent my tb to bo white to port. he says the ave. gain on his tb are 8rwhp and I also have all royal purple fluids running in the car.
Old Oct 21, 2007 | 01:51 PM
01Z28M6's Avatar
The LS1 already has a good fuel system that is good for a lot more than the normal demand. The LT1 is not quite so good. I just arbitrarily used 350 hp as a boundary. The V-plus volt booster is on my cars because I have nitrous wet kits where you can't afford a marginal fuel supply. It's one of those modifications that takes 10 minutes to install, cost about $80 and you almost never think about again. It's probably overkill but that's what high performance is all about.
Old Oct 21, 2007 | 08:11 PM
IFRYRCE's Avatar
I have it, I see 16+ volts at WOT (HPtuners log, not gauge). My headlights get noticeably brighter.
Works as advertised, good mod. I like mine.
