Need a larger diameter tensioner pulley
Old Oct 10, 2007 | 10:29 AM
BadgeZ28's Avatar
Default Need a larger diameter tensioner pulley
I am using a manually adjustable belt tensioner on my LS1 motor with a powerdyne supercharger. I am just a bit off on belt size and max out the adjustment with the stock tensioner pulley. I am looking for a larger diameter pulley to replace it. Thanks
Old Oct 10, 2007 | 02:47 PM
ls2 bait's Avatar
try the supercharger pulley from a buick regal sc.
Old Oct 10, 2007 | 04:50 PM
BadgeZ28's Avatar
ls 2 Bait is this the one? Thanks
http://www.autopartswarehouse.com/se..._search=Submit
Old Oct 10, 2007 | 05:00 PM
studderin's Avatar
You can get go to the local AZ/PA and look thu them. dayco makes the plasitc 6 ribs in 101mm (3.5) and 76mm (3.0). I change the sizesall the timeon GTPs for this. heres a pic if they wnat a refrance. And the guy/kid isnt cool to let you look thu them. Motor would be a 3800 supercharger seriseII (L67) the vin will be 1 if they ask. Pulley "8" is the 3.0 6rib, but thay also make a 3.5
Old Oct 10, 2007 | 05:17 PM
BadgeZ28's Avatar
Thanks for the info. Really appreciated
