Question on my ls6 intake
Old Oct 16, 2007 | 07:15 PM
tasilver's Avatar
Default Question on my ls6 intake
I just bought this ls6 intake and it came in today. It is the intake in the pics. I got exactly what was in the pics. This will be the first time I have swapped a intake. Do I need all of the stuff on it. I do not think my ls1 intake has the extra pieces. Any one need these pieces if cant use them?
Old Oct 16, 2007 | 07:25 PM
King Nothing's Avatar
did you get the plugs for underneath and the new gaskets? other than that you should be good to go. i honestly don't know why some people grind away at their blocks when they can easily buy the plugs almost every chevy pontiac dealership keeps in stock
Old Oct 16, 2007 | 07:27 PM
lastcall190's Avatar
Clothespins for the rear 5 intake bolts. Makes it very easy to have them held up when you pull the intake off the motor. Good luck.
-J
Old Oct 16, 2007 | 07:34 PM
tasilver's Avatar
I have ordered new gaskets and the coolant block off. I also ordered the air and egr block off plates for my headers. Do I just pull the egr out? what about the air?
^Thanks I will use the cloths pins to hold up the bolts, good idea.
Old Oct 16, 2007 | 07:47 PM
I thought the OBX were all race style. In any case, what you'll do is pull the EGR off, you could still use AIR if you wanted, LS1/LS6 intake has no bearing on that. I'm not entirely sure if I answered your question tho
-J
Old Oct 16, 2007 | 09:08 PM
98nosz28's Avatar
I used small pieces of hose to hold up the rear bolts on the intake.
Old Oct 17, 2007 | 07:26 AM
tasilver's Avatar
OBX have the egr tubes and all of the O2 bungs unless they have changed, I have had mine for a year. I guess I will search on how to get rid of the air. Does the egr cause a poping noise in the exhaust?
