Rod bolts, Prothane mounts INSTALLED with pics!
Old Oct 24, 2007 | 10:51 AM
odarabla's Avatar
Looks great man!! Great job!!
Old Oct 24, 2007 | 07:26 PM
socmguy's Avatar
Restricted User
Originally Posted by DopeFedZ
He used rattle cans. Nice work man. I did the CETA mod with spray paint and my coil packs and they are holding up excellent.
thanks, I'm confident it'll hold up. That area of the car doesn't take much abuse aside from the occasional ratchet hitting it.
Old Oct 26, 2007 | 02:11 PM
socmguy's Avatar
Restricted User
Originally Posted by Tainted
gee where oh where have I seen you before?
You should have told me yall were doin that **** I could have halped, I know allllll about taking them rod bolts out and motor mounts.
yeah dude, you really missed out on all the "fun"
Lowering K member and installing motor mounts in a garage w/ jacks does not = fun
Old Oct 26, 2007 | 10:08 PM
CULATR's Avatar
Originally Posted by MeentSS02
I'm glad I replaced my battery before it did that...I have heard way too many stories about that happening.
I also noticed that your power steering pump looks like it is on its way out...mine was leaking just like that, and I just went ahead and replaced it with a Turn One pump. No leaks for me
Not to hi-jack the thread but are you talking about the leaking around the power steering cap? if so mines doing the same and i am concerned about this now ??
Old Oct 27, 2007 | 01:38 PM
socmguy's Avatar
Restricted User
I wouldn't worry about that, it may spray a little out of the cap when you reach the turn-stop point. It's pretty normal.
Old Oct 27, 2007 | 01:54 PM
CETA_TransAm's Avatar
looks great
Old Oct 27, 2007 | 06:09 PM
The Alchemist's Avatar
UNDER PRESSURE MOD
Looks great... as for the power steering issue, that's normal. It's called boiling power steering fluid which is typical of f-bodies without power steering coolers.
You have a couple inexpensive choices to fix the issue. Go with a higher boiling point power steering fluid, I think RedLine makes a good one, second, get an inexpensive plate cooler to mount on the front on the air conditioning condensor. You can get one for less than $50 from Summit or Jegs.
Again nice job on cleaning up the engine bay.
Old Oct 27, 2007 | 06:15 PM
Tainted's Avatar
you know what was funner? taking out my entire motor just to bend all ym exhaust valves and ahd to pull the heads off today.
thats fun
Old Oct 28, 2007 | 07:06 PM
socmguy's Avatar
Restricted User
yeah, read your thread Tainted. What a kick in the nuts, and you were so close too. I'll be thinking about you when I'm running the streets dusting cobras.
Old Oct 28, 2007 | 08:18 PM
Tainted's Avatar
look here *****, ill have it before to long. my heads are off, front cover is off, im having teddy actually degree in the cam, and the heads are goin to the machine shop tomorrow. maybe we can go for a cruise before long. Im gonna go for a pic shoot out at the wildlife reservation out past the fortbragg reservation area. its goregous, and with the falling leaves it'll be cool as hell.
Old Oct 28, 2007 | 08:33 PM
so did the those new motor mount make the car vibrate or shake ?
Old Oct 28, 2007 | 10:05 PM
  #32
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
That's definetly a big change from start to end. Good job.
Old Oct 28, 2007 | 10:56 PM
  #33
socmguy's Avatar
Restricted User
Not a whole lot. The biggest change I saw with the mounts is that 1. the motor doesn't shake all over the engine bay now (torquer v.2) 2. when I let the clutch out now, it's much smoother. When I let it out before the motor would tweak and then the clutch would put the power to the wheels. 3. when a rev on idiot GT drivers (that think they've got the fastest car on the street for some reason), the whole car twists a little. I couldn't be happier. Like I said earlier. Good project to schedule when you've got more time than money.
Old Nov 3, 2007 | 02:29 PM
  #34
second_2_none's Avatar
nice work man! that **** is sick looking!
Old Nov 3, 2007 | 02:55 PM
  #35
MdFormula350's Avatar
nice work, those engine mounts are well worth it install time! which in your case wasnt that bad since u had the k-member down.
Old Nov 3, 2007 | 03:44 PM
  #36
Tainted's Avatar
Brandon, next time I scream at you on skibo, look around and wave back so I dont get the people next to me to look at me like im a schitzo
Old Nov 5, 2007 | 06:58 PM
  #37
socmguy's Avatar
Restricted User
Haha! Broke your cherry Avery. 1st Post!
Old Nov 5, 2007 | 09:59 PM
  #38
Elcaballoloco's Avatar
but you are a ******* schitzo tainted....you dont need to be screaming on skibo to look like one!
whats up brandon? looks good man, sweet job.
Old Nov 6, 2007 | 03:48 PM
  #39
Tainted's Avatar
you cant wave back for **** either erik, yall must hate me
Old Nov 6, 2007 | 07:00 PM
  #40
i didnt even see you....you sent me a text dude....i think you're gay *** is stalking me. i didnt see that colorado at any light around.
