How Many 02 Extensions Needed for Header Install?
Old Jun 11, 2003 | 12:59 PM
Josh's Avatar
Default How Many 02 Extensions Needed for Header Install?
How many 02 extensions are needed for a header installation? In particularly, the QTPs? I'm having a y-pipe custom made using the stock cats, and am retaining all of the emissions equipment.
And would I need 02 sims for any reason or are those strictly for an ORY? I really don't have a clue about any of this 02 stuff, so any and all help is greatly appreciated.
Thanks,
Josh
Old Jun 11, 2003 | 01:29 PM
Ferocity02's Avatar
Default Re: How Many 02 Extensions Needed for Header Install?
No idea on the O2 extensions but you only need the O2 simms if you are running an off road y-pipe.
Old Jun 11, 2003 | 02:01 PM
Sonny's Avatar
For qtp, I used 1 o2 ext. - the driver side o2 sensor is longer than the pass one. so swap that to the pass side and use the ext w/ the pass o2 for the driver side.
Old Jun 11, 2003 | 03:04 PM
DarkLordFtT's Avatar
I used 1 for my jet-hot on the passenger side to get the wire behind the starter and away from the heat. Mines a 99 also. <--- cool new smiley
