Throttle body porting
Old Oct 25, 2007 | 12:29 AM
SSChevy99's Avatar
Default Throttle body porting
I've heard you can port the stock throttle body on a ls1. but what exactly do you port? and how much power will it give me?
Old Oct 25, 2007 | 12:30 AM
CaMaRo67RS355's Avatar
some ppl see 5-8 hp to the wheels depends. i got a 01-02 for sale with sensors if ur interested im flexible on price.
Old Oct 25, 2007 | 12:35 AM
SSChevy99's Avatar
Just the throttle body? how much you want for it?
Old Oct 25, 2007 | 06:54 AM
teke184's Avatar
there is a radiused "lip" on the filter side of the throttle blade.
this causes a small restriction...maybe 2mm on each side...in the TB.
but if you do the math, the difference in surface area between a circle 71mm in diameter (2mm narrow on each side) and one that is 75mm is 10.4%
so that's a healthy amount of flow.
heres a diagram i made to illistrate:
and the finished product. i did it myself...just threw the whole TB on a lathe and machined down the lip.
Old Oct 26, 2007 | 09:05 PM
SSChevy99's Avatar
Cool. thanks a bunch!
Old Oct 26, 2007 | 10:42 PM
BriancWS6's Avatar
There's alot more to it than just removing the ridge if you want to see some decent gains. Here's mine that I did back in 05. Sorry for the shitty cell phone pic, I need to take a new one.
Notice how not only did I remove the ridge in front of the blade, but I also increased the size of the entire TB opening. See how much thinner the outer edge of the mouth of the TB is? Then on top of that I did the half-shaft mod, the bumpstop mod, and touched up the actual blade itself.
Old Oct 26, 2007 | 10:58 PM
ApexVIII's Avatar
you get about 8rwhp, its a good cheap mod!!1
