porting and polishing tb
Old Oct 25, 2007 | 03:49 PM
2KnbmTA's Avatar
Default porting and polishing tb
just wondering what you guys use to port and polish your throttle bodies. i want to do mine but im not sure what to use.
Old Oct 25, 2007 | 04:06 PM
0utLawZ28's Avatar
u can use a drimel and use those sand paper rolls and the little cut off wheels
Old Oct 25, 2007 | 04:41 PM
FireSilverLullaby's Avatar
Yeah i used the same thing
Old Oct 25, 2007 | 05:23 PM
Smokin87TA's Avatar
Restricted User
Best thing to use would be an air die grinder, first start off with a metal carbide bit, not aluminum because it will take off too much material and could dig in. The go to different grit sanding rolls from 60 to 320ish, then you can hand sand with some 400 and hit with some polishing wheels and compounds. Good luck, take your time and it will come out great. Tim
Old Oct 25, 2007 | 05:45 PM
CLUBBER LANG's Avatar
not to highjack. but what compounds do you use to polish it?
Old Oct 25, 2007 | 06:12 PM
0utLawZ28's Avatar
polishing compound / buffing compound
Old Oct 25, 2007 | 06:46 PM
Smokin87TA's Avatar
Restricted User
Well i cant give away the exact compounds i use as i have many hours in trial and error, but a tripoli compound first followed by a white rouge for aluminum will get you great results, just make sure you use 2 separate polishing discs. Tim
Old Oct 25, 2007 | 07:42 PM
Wicked2002TransAm's Avatar
dremel and sand paper rolls is what i used to port it
