AC problem (think its compressor)
Old Jun 12, 2003 | 01:49 PM
Crazyquik's Avatar
Default AC problem (think its compressor)
Ok, well my AC blows, but not cold.
So I assumed it needed recharging and went and got 2 cans of R134A and one can of oil.
Go put the little hose on it, and it wont take a charge. Mess around with that for a while, making sure the hose isn't clogged, even try another hose. Still wont take.
So I take it to a little local mechanic and he slaps some guages on the Hi and Lo ends, and they are both reading basically the same pressure, around 125 to 130 I think. He seems to think something is wrong with the compressor, yet a visual inspection of it shows that both the inside and the outside of the wheel are spinning. He refered me to another shop.
Any ideas?
J.
Old Jun 12, 2003 | 03:10 PM
383LQ4SS's Avatar
Default Re: AC problem (think its compressor)
was it blowing cold prior to adding freon?
If yes...compressor or expansion valve.
Other wise it could be overserviced. 134a systems will not cool well when over serviced. Recover the freon, vacum down, then add the exact amount called for in the manual.
Old Jun 12, 2003 | 07:36 PM
Crazyquik's Avatar
Well it hasn't blown cold in over a year. I was just too lazy to service it last summer (I assumed that all I needed was a recharge).
Now I want to fix it, but in retrospect delaying it a year probably wasn't a good idea. Although if this turns into a money pit I'll just say forget it and I'll remove the entire AC system.
J.
Old Jun 12, 2003 | 08:20 PM
wrencher's Avatar
wrencher
Have seen a few a/c compressors snap the shaft.
The clutch engages, spins the drive hub but the
compressor does nothing. Your gonna prolly need a new compressor. But along with that replacement,other things have to be done to make it right & cover the compressor under a warranty.
You are gonna need a new accumulator/drier, & oriffice tube. Then importantly the system will need to get flushed. When the compressor took a $hit it likely sent metal debris into the system.
So the evaporator & mostly the condenser need to be flushed. It sucks but there is a right way...
You can go get a junk yard one, but if it injests old compressor fragments your back where ya started.
Old Jun 12, 2003 | 08:48 PM
WILWAXU's Avatar
Like Al said, R134 is very "sensative" It's not like R12, you can only add just enough, to much and it won't cool.
More than likely, some how you have lost vacuum on the system. Need to have it vac'd down and replace the freon.
Old Jun 12, 2003 | 10:33 PM
Crazyquik's Avatar
Ok, John, so you're talking like 50 bucks or 100 or what? Ballpark of course.
Replacing the accumulator/evap/compressor, etc and then flushing the whole deal and refilling, that sounds more like 300-600, right?
J.
Old Jun 13, 2003 | 07:43 AM
Smoke T/A's Avatar
J.
Hey I have the ac compressor, accumilator, lines and condensor off of my 98 Z. I took it off befre the car had 9000 miles on it. It hardly had any run time in it. I'll let all of it go for $250+ shipping LMK
Joe
Old Jun 13, 2003 | 08:33 AM
Crazyquik's Avatar
See thats the thing, mine doesn't have 9000 miles on it yet either! I bet there isn't 30 hours of run time on these components.
J.
 Michael S. Palmer
Old Jun 13, 2003 | 09:48 AM
mobius's Avatar
just had the same thing happen to mine, comresssor spins ie clutch engages but wouldnt take a charge. i replaced it airdryer/acc and orifice tube after flushing draw vacuum and everything. get the pressures right on it and it didnt feel real col but was ok. 3 weeks later the new compressor siezes car stalls turn it on and it is making all kind of crazy noises so i take off the ac belt and all is good. at least they are replacing the compressor and airdryer under warranty. hopefully the new one works better...
Old Jun 13, 2003 | 11:30 AM
WILWAXU's Avatar
I'd take to a local shop and let them diagnois it. It may save you $$ in the long run.
Old Jun 13, 2003 | 12:16 PM
wrencher's Avatar
wrencher
300-600 is alot on the low side.., These parts are expensive!! I recommend going with a delco but there 300-400 alone GM has been having various issues with A/C compressors all across the board as of late. Do you have an extended warranty that'll help??
Old Jun 13, 2003 | 04:50 PM
andy98Z's Avatar
I have a compressor fs off my 2000 SS let me know.
