what heads?
Old Oct 29, 2007 | 04:32 PM
scramblerman's Avatar
Default what heads?
I'm looking into getting a set of heads to go along with my MS4 cam in a 02 Z06.
What is the differance between Ls6, L92, Ls7, 6.0, and 5.3l heads???? What would be the best set of heads for my setup at a decent price. Not looking to go nuts and get AFR's, even though I know they are really good. Is the price in heads really worth the extra bit of hp? What type of hp gain would I get with aftermarket heads over the stock LS6 heads?
Was looking at these
http://www.texas-speed.com/shop/item...d=134&catid=20
or would these heads be better with the comp valve job be better???
http://www.texas-speed.com/shop/item...d=649&catid=20
Old Oct 29, 2007 | 04:45 PM
Smokin87TA's Avatar
Restricted User
Might want to post this in the gen III internal engine forum, you will get better answers there.
Old Oct 29, 2007 | 04:47 PM
Smokin87TA's Avatar
Restricted User
But with the ls1/ls6 block you are not going to be ablt to run l92, or ls7 heads because they are a 4" bore head. As far as ms4 cam is concerned, i dont think it would work with 5.3's without flycutting and the ls6 and 6.0 heads are the same but 6.0 heads will lower compression unless they are milled. I would seay your best bet it to go with a cnc'd ls6 head, call tsp and they will get you the best heads to match their ms4 cam. Tim
Old Oct 29, 2007 | 05:18 PM
Thanks. I was kind of figuring I had to go with the LS6 heads. Can get confusing with the diff. types of heads on the market. btw posted in the internal section.
