# 3 Miss Fire
Old Oct 30, 2007 | 08:56 AM
my number 1 hater's Avatar
Default # 3 Miss Fire
Got a # 3 miss fire..Just changed the plugs... One step colder for the spray...I am going to swap in the old plug with an OE wire hope that fixes it. What should i look at next The coil, intake, ?????????
Old Oct 30, 2007 | 04:57 PM
Dex's Avatar
Dex
If it happened right after a plug change that is most likely your problem. After that its the coil, the wireing to the coil or the wiring to the injector or the injector its self.
You could also swap the plug and wire from the cylinder next to it?
Old Oct 30, 2007 | 05:09 PM
Spiewalk's Avatar
How do you know it's your #3 cyl missfire?
Old Oct 30, 2007 | 05:50 PM
code P0303 on my scan tool says #3 cyl missfire..
Old Oct 30, 2007 | 05:51 PM
did not help ....... Looking at the coil and wiring next....
