Volant instructions! HELP!
Old Oct 31, 2007 | 01:07 PM
RawDawg's Avatar
Default Volant instructions! HELP!
I had my volant intake "professionally" installed by one of the site sponsors and drove from florida to california. When I got here i was under the hood and noticed that the intake looked a little crooked. So I just tapped it to center it and ......off it came!! I'm trying to fit it all back together snugly but the MAF and Y split dont quite marry up flush.
Does anybody have the instructions it came with?? The site offers absolutely NO instructions. If anybody has a softcopy they can e-mail or post I would appreciate it greatly!!!
Old Nov 1, 2007 | 01:05 AM
Soul TKR's Avatar
best I could find...
http://www.rksport.com/pdf/07093401.pdf
Old Nov 1, 2007 | 11:39 AM
RawDawg's Avatar
I think this is all they sent with it. THANKS I appreciate it! The reason it might not be fitting snuggly might be cause of the SLP smooth bellows. Anybody have any ideas? How much difference is that smooth bellows making?? Should I switch back to the stock bellows?? Every thing is together but not flush.In between the bottom of the MAF and the Y split there is a small split that I can't force any closer together.
Old Nov 1, 2007 | 12:10 PM
bigti99a's Avatar
smooth bellows prob not much other than visual mod. the slp is tough to bend and i would switch it out if it fixes your issue. no real power difference, if you like the look there are more plyable ones out there.
Old Nov 1, 2007 | 07:50 PM
nytmare1's Avatar
I have a Volant and during my research here and on other LSx forums, I found that the smooth bellows doesn't work well. I stayed with the stock bellows for this reason and the fact that a smooth bellows really doesn't do that much for air flow.
Marc
Old Nov 15, 2007 | 12:56 PM
RawDawg's Avatar
I went back to the factory bellows and it still didn't fit correctly. I ended up going to the home depot and getting a 4 to 3 inch plumbing coupler!! Works great and fits perfectly! Doesn't look bad either! Hope this may help someone out there...
