Building my ownd Dual set up??!!
Old Nov 2, 2007 | 11:54 AM
Eatinstang4life's Avatar
Default Building my ownd Dual set up??!!
Just need some suggestions. I have alrady purchased 3.5" in/out moroso spiral flows I got a great deal on them or I would have just got the 3" ones. I have pacessetter long tubes, What I am thinking about doing is just buying the universal 3" x-pipe dual kit from jegs or summit and modding to fit up to my headers. Should I just buy slip on pipes to connect my headers? Should I just get the 3" pipe flared out so I can weld the morosos to it? Any suggestions would be much appreciated. Thanks
Old Nov 3, 2007 | 07:46 PM
Anyone?
Old Nov 3, 2007 | 08:14 PM
spare tire's Avatar
Are you running it over the axle?
Old Nov 4, 2007 | 09:27 AM
Dumped before the axle!
Old Nov 4, 2007 | 09:57 AM
Full-Force's Avatar
You will need to buy an extra U bend to make the driver side work.
Old Nov 4, 2007 | 10:44 AM
Yea I already have a j bend 3" pipe from another project. Im guessing I will have to extend the driver side pipe from the jegs kit then turn it in a little to match up with the header
Old Nov 6, 2007 | 06:40 PM
noone else has built thier own dual system?
Old Nov 6, 2007 | 06:45 PM
Full-Force's Avatar
Thats correct. You may also have to use part of another bend to make the driver pipe exit the x at more angle to clear the tranny x-member.
