coolant line question
Old Nov 3, 2007 | 09:23 PM
shaun's Avatar
Question coolant line question
hey guys i have a question. my car is a 98 but i have a 02 engine when the motor was swaped all the emisions where left on so i still have the ls1 intake.
im wondering if the the ls6 factory lines that came on the 02 engine are the ones i have now. will the ls1 intake work with the ls6 lines? is there a way to tell what lines i have? thanks
Old Nov 3, 2007 | 09:39 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
The LS6 will have two plugs behind the intake, one of each head. They look like the picture below
Old Nov 4, 2007 | 12:12 AM
shaun's Avatar
well the front metal coolant line looks like the pic and it goes under the tb like between the manifold and tb
Old Nov 4, 2007 | 06:17 AM
Z28/2002's Avatar
If it goes under it then it still has the LS1 coolant lines. The LS6 intake will work with them but you either have to cut the ribs off the bottom of the intake or flatten out the coolant lines. Try a search and you'll see what I am talking about because a couple of people have done it this way
