tb question
Old Nov 6, 2007 | 08:57 AM
3rdgentug's Avatar
Default tb question
i have a 78mm fast intake fixin to go in, and currently have the ported thunder racing tb 78mm on my stock intake. i also have a 85mm delphi maf and 85mm ftp lid going on same time .
would i see any more gain at all going to say the bbk 80mm tb over my stock ported, should i mabey even consider a 90mm tb?
thx!
Old Nov 6, 2007 | 09:10 AM
Transam295s's Avatar
you gotta remember one thing. The opening on the intake is still only going to be 78. So you can force all the air you want in up tot hat point its only still going to flow through there the same. So im thinking maybe just get your stock tb ported. you will see gains for sure on a stock ported TB. tons of vendors on here are doing it for dirty cheap these days. Most even do the bump stomp mod for you.
Old Nov 6, 2007 | 09:55 AM
Brads LS1 02Z's Avatar
keep the ported stock TB... i had a bbk and thought it was a pos
Old Nov 6, 2007 | 11:51 AM
3rdgentug's Avatar
yea i already have a stock ported throttle body, its the one thunder racing did, only thing it doesnt have doen is the epoxy mod.
Old Nov 6, 2007 | 11:52 AM
radkon's Avatar
Port the stocker. The 90 MM TB won't fit without an adapter and won't do any good.
