GTO Cooling Fan Issue
Old Nov 13, 2007 | 09:27 AM
Fedge's Avatar
Default GTO Cooling Fan Issue
My buddy has an 04 GTO with the following problem: The fans turn on like they are supposed to, however they will not shut off. They will run long after the car is turned off and until the battery dies. I think it's the fan switch or the coolant temp sensor...anyone else have this issue?
Yes, I tried searching
Old Nov 13, 2007 | 09:43 AM
69LT1Bird's Avatar
Check the fan relay #2, there should be two, low and high speed. Unplug the #2 relay toverify that the fan turns off. If it does, replace the relay. If it stays on you have a short to ground in the fan 2 relay coil control circuit or Short to ground in the fan motor high speed ground circuit. Odds are goo that it is the relay.
