Would someone explain to me the throttle body "cam"?
Old Feb 22, 2008 | 01:57 PM
5.0stang's Avatar
What is the stock throttle body size from year to year?
Are they the same as the corvette?
I thought someone said that the throttle bodies are 75mm at the opening, but 71.5mm at the back of the throttle body.
Old Feb 22, 2008 | 02:22 PM
Red99TA's Avatar
I thought they were either 75mm or 78mm (can't remember which). The LS1/6 vettes are the same size as the LS1 F-bods...and all F-bod years are the same size too.
Old Feb 22, 2008 | 02:55 PM
Pro52R's Avatar
Vettes are Drive By Wire IIRC after 98
Old Feb 22, 2008 | 03:36 PM
Red99TA's Avatar
Well I can vouge for the '02 being drive by wire
Old Feb 22, 2008 | 05:11 PM
5.0stang's Avatar
If anyone has a throttle body off the car, try to get a good ACCURATE measurement of the front and back of the throttle body. I am pretty sure it "necks down."
Old Feb 28, 2008 | 01:05 AM
2000 ta's Avatar
how hard would it b to change to the older style?
Old Feb 28, 2008 | 01:07 AM
2000 ta's Avatar
also where would b a good place for some info on home porting?
Old Feb 28, 2008 | 08:58 AM
Red99TA's Avatar
Just do a search on this site. Several guys have posted up step by step instructions on how to port. Really you just need a small sanding drum for your drill and various grit drums to put on there. I port the TB metal down with a coarse sanding drum and then follow up with a fine drum. Next I do 120 - 220 - 400 -600 all by hand to get it really smooth before I polish it with a buffing wheel. The polishing is pretty much just for looks as it doesn't really help airflow. If I didn't do any hand sanding it would only take me maybe an hour to port, TB half-shaft, and bump-stop mod all at once.
Old Feb 28, 2008 | 12:07 PM
2000 ta's Avatar
thank you 4 the info.big help!! thanks again
