TB help
Old Nov 24, 2007 | 04:07 PM
WS.6#384's Avatar
Default TB help
I hope you don't mind me using your photo GoFast908Z. I have been having a hard time finding a quality pictured TB install. I ended up selling my 02 TB that came with my LS6 intake because my 98 TB was ported. I am having a hard time getting the cable tension back right. Also, unless I am missing a cable I only have one? Can someone help me with the proceedure for tightening the cable? And maybe post some good pics?
Old Nov 24, 2007 | 05:04 PM
SweeTbone's Avatar
You only have one cable because you have TCS. Follow the single cable back from the TB up to this inline fuse looking thing. There will be two of them on two different cables. One coming from the firewall going to the TCS module, then another from the module to the TB. I believe you can adjust the tension there. Switching from a LS1 intake to an LS6 intake then to a FAST 90 and NW TB and I have never had to mess with those.
First things first though, make sure you have the throttle cable clipped in the right hole on the bracket. It goes in the hole on the inside towards the manifold. If you are looking down at it, the right hand hole. I have put mine in the left before.
Old Nov 24, 2007 | 05:46 PM
WS.6#384's Avatar
Thanks alot SweeTbone.
