Pacesetter passenger side LT clearance Question with PIC! Ok guys, I haven't finished tighting all the bolts, I can probably get the header to rise about another 1/4 to 1/2 inch but generally speaking does the passenger side hang lower than the driver side? http://i51.photobucket.com/albums/f3...g?t=1196031920 http://i51.photobucket.com/albums/f3...g?t=1196032064 |
anybody? ttt... |
The passenger side sits a little lower then the drivers side. |
I have the same headers and they look the same as yours. |
Wow, that makes it the lowest point on the car, sort of... Either way, like I said I can get it a 1/4 to 1/2 inch higher when I tighten the bolts I was doing it alone with a rope tied along the tubes and my arms and hands got tired as ballz. Tomorrow it is! |
not sure if this is gonna help you out too much but this is what mine looks like bout the same. http://img408.imageshack.us/img408/4...ture018cd1.jpg |
Looks the same, thanks guys! |
Yes, passenger side sits lower, but the driver's side of the y-pipe drops down to clear the floor brace so both side sit around the same height. The picture above shows the driver's side y-pipe dropping down before it wraps around to the center of the car. |
did you get ones with egr or full race ones |
© 2024 MH Sub I, LLC dba Internet Brands
