Pacesetter Install ??
Old Dec 5, 2007 | 12:22 PM
01CaMMMaro's Avatar
are you using a ratchet wrench?
Old Dec 5, 2007 | 12:57 PM
Titanws6's Avatar
For what, the install is done.....
Old Dec 5, 2007 | 02:16 PM
01CaMMMaro's Avatar
ahh didnt know you were done... was just going to suggest using a ratchet wrench because they can get in tight spots and would be the ideal tool for puting those bolts in until you have to torque them down.
Old Dec 5, 2007 | 02:36 PM
Titanws6's Avatar
I reused the stock bolts and am going to do the heat cycle method of making sure they are tightened.
What ft/lb should I torque them too?
Old Dec 5, 2007 | 05:30 PM
Spiewalk's Avatar
11ftlbs first pass, 18ft lbs second pass, working your way outwards from the inside. I just finished my install to, everything went well, cept I was unable to torque down all the bolts on the pass side... I just can't get the torque wrench on the bolts. Try your best and use your hand meter.
