Anyone have the Volant CAI
I like the way it looks when you pop the hood, and it makes a healthy growl. As far as real numbers go I am not sure at all.
But... One more time: 1) The Volant was designed to fit the non-Ram Air hoods. If you want it to seal to a Ram Air hood, you need to fit some foam tubing around the box's original rubber seal. 2) There's really no diffinitive testing results comparing a Volant to a lid. What little bit of testing that has been done indicates that the Volant works just as good as a lid. If the Volant works better than a lid, it's nominal at best. The only real difference between the two is the looks.
Marc
