exhaust cutout wiring question
Then:
1. Ground it to anywhere on the car. I used the ground wire to my TCS switch.
2. Wire the positive wire to the PINK wire on your traction control harness (TCS button for trans am or ASR button if Camaro). Even if you don't have traction control, the harness is still back there and you can still tap into it.
This way proved to be the easiest way for me and I searched and read about it quite a bit before I went through with it. Mine is the McCord and has worked this way flawlessly for nearly 2 years now.
