how will i know if blew a head gasket ???
Old Dec 5, 2007 | 06:59 PM
sl99ls1's Avatar
Default how will i know if blew a head gasket ???
i installed my lt's and ory 3 weeks ago but i didnt buy 02 sims or get a tune so my service engine light been on and my car has been running real good and hard well today i was on the free way going about 70 mph in 6 th gear and my ses light started flashing didnt really think anything of it. well i got home and parked it for like 2 hours and then when i was going to the store it started back fireing really bad and white somke was coming out of my tail pipes and when i give it gas it fills like my whole car shakes.......can somone tell me what this can be????
can it be that i just need a tune
or can it be that one of my o2 sensors is not working and making it run rich/lean
or can it just be that i blew a head gasket
Old Dec 5, 2007 | 07:08 PM
LTLRDSS's Avatar
if it was a head gasket you would have coolant coming out of your exhaust
Old Dec 5, 2007 | 07:15 PM
sl99ls1's Avatar
I Have'nt Had That Happen Yet...wat Else Could It Be??
Old Dec 5, 2007 | 07:16 PM
_JB_'s Avatar
Also your oil will turn milky. Check your oil ASAP, any knocking sound?
Old Dec 5, 2007 | 07:58 PM
sl99ls1's Avatar
The Oil Looks New But When I Start It, It Back Fires Like 5 Times
Old Dec 5, 2007 | 08:11 PM
koolrayz's Avatar
flashing SES is a bad misfire. probably tune related due to the lack of tuning after the new modifications. You know you have to tune out the o2's or simulate. probably will foul plugs and cause all kinds of other issues if you continue to run the car with a bad tune. I really doubt you have a head gasket issue. Have you noticed the coolant level in the overflow going up or down outside of it's normal range in adition to what the others mentioned?
Old Dec 5, 2007 | 09:13 PM
sl99ls1's Avatar
the coolant temp is good nothin wrong but why do you think it is smokin white????
Old Dec 5, 2007 | 11:11 PM
sl99ls1's Avatar
Old Dec 5, 2007 | 11:49 PM
sl99ls1's Avatar
?????????????????? someone has to know
Old Dec 6, 2007 | 01:06 AM
DMONEY06's Avatar
change your plugs mine was doing the same thing
Old Dec 6, 2007 | 01:21 AM
waldershrek's Avatar
If you are getting white smoke it might be a head gasket. Check your coolant level and oil level every day for 2 weeks. If your coolant keeps getting lower and your oil gets fuller and milky then you have a head gasket problem.
Old Dec 6, 2007 | 02:41 AM
ErikElvis's Avatar
Check your plugwires. May have unclicked or melted one on the LT. And I had flashing SES's that were primary O2 related. Check for melted/drug on the road O2 wires. Ive been through all of that.
Old Dec 6, 2007 | 03:25 AM
99mongooSS's Avatar
yep same here
Old Dec 6, 2007 | 09:11 AM
koolrayz's Avatar
The white smoke and the backfiring are most likely from unburnt fuel. I cannot understand why you would not fix what you know is wrong first (tuning).
In regards to the headgaskets. The coolant temp tells you nothing in this case. The coolant level in the overflow will go up if you are pushing gas from the cylinders into the water jackets, this is commonly refered to as pushing water. The level will also go down, the coolant could go into the oil or be pulled in the cylinders during the intake stroke and pushed out the exhaust.
Old Dec 6, 2007 | 11:51 PM
sl99ls1's Avatar
i took my plugs out today and they were soaked in fuel i think i need a tune now
Old Dec 7, 2007 | 12:08 AM
slowandrichws6's Avatar
mine was doin the same thing, let it run and warm up then squirt water on each primary tube of you headers, if it doesnt steam up then thats the cylinder(s) that arent hittin. in that case check you spark plugs/wires. i craked my sparkplugs puttin headers on. hope this helps any
Old Dec 7, 2007 | 02:06 AM
kirby's hawk's Avatar
If you can try going to autozone and have them scan it for you, they do it for free.
Old Dec 7, 2007 | 01:49 PM
tripps's Avatar
After headers you are probably running rich, and your plugs might have gotten fouled out. Get a tune and then change your plugs, or vice versa. just do both of those as soon as you can.
