What to use and how do you set the idle set screw?
Old Dec 6, 2007 | 04:37 PM
CJDZ24_Z28's Avatar
Question What to use and how do you set the idle set screw?
I just got the code for low TPS voltage on my 00 Formula. The car is reading reading low. I tried my smallest socket and it doesn't fit on the underside of the TB. Thanks
Old Dec 6, 2007 | 06:20 PM
thechef's Avatar
Moderator
if i remember correctly i think its is a torx screw its been years since i have had to adjust one
Old Dec 6, 2007 | 08:54 PM
dlandsvZ28's Avatar
My tuner removed the TB and inserted the set screw from the top. Easier to adjust from the top compared to the bottom.
Old Dec 7, 2007 | 03:32 PM
rel3rd's Avatar
That's what I did...works great. T-15 is the size, I believe
Old Dec 7, 2007 | 06:53 PM
CJDZ24_Z28's Avatar
Thanks fellas!
