Purchased my KOOKS today...
Old Dec 8, 2007 | 02:16 AM
skewba98z28's Avatar
You will have to remove the oil filter to get the driver side on without removing the steering shaft. Might aswell do a oil change while your at it.
Old Dec 8, 2007 | 08:02 PM
LivernoisMotorsports's Avatar
Mr. Harris,
Sometimes F-Bodies with headers have this issue. We've done several cars even with stock mounts that haven't had any issues. I just spoke to Saso and he was under the impression that everything was good when you picked the vehicle up. He said he went for a ride with you and there was no issues. We're willing to do whatever it takes to make things right.
Regards,
Rick LeBlanc
Livernois Motorsports
Originally Posted by 02 wife
Get the poly mounts! I just had a set of kooks long tube headers installed and they bang on my floorboard! Livernois Motorsports neglected to tell me about changing my stock mounts till after I had them installed! They are so much easier to install while doing the headers! now I have to pay another shop to install the poly mounts!
Old Dec 9, 2007 | 11:34 AM
RareBreed0295's Avatar
Livernois, do y'all suggest to get the motor motor mounts when you go to install LTs?
Old Dec 9, 2007 | 01:00 PM
We've installed the mounts on some cars and still had them hit. There just isn't a lot of room and there's always a chance with the large tubing that they will hit.
Regards,
Rick LeBlanc
Old Dec 9, 2007 | 01:09 PM
How much are a set of motor mounts? Is there any comfort differences with the polys in while driving?
Old Dec 9, 2007 | 03:01 PM
02 wife's Avatar
Regards,
Rick LeBlanc
I'll apolgize for the *** Hole comment! I had to pay $130.00 for them to bang my undercarriage I had no idea it would be such a problem. And it still bangs!
Old Dec 10, 2007 | 04:58 PM
Just recieved my headers today. Hopefully i will get to install them this weekend.
Old Dec 11, 2007 | 09:43 PM
Do y'all think that i will be able to feel a power difference once i get the headers and true duals installed. Then a good tune..
Old Dec 11, 2007 | 09:50 PM
lastcall190's Avatar
Absolutely, IMO.
-J
Old Dec 11, 2007 | 09:53 PM
Ill be doing my install this saturday along with some SFCs and a stb from sam strano. Im hoping the sfcs will help keep water from coming in through the t tops.
Old Dec 12, 2007 | 07:32 AM
NOBR8KSS's Avatar
The biggest issue I usually hear about is not having the car high enough to get the headers slipped in from underneath. I think that the car needs to be a good 24" off the ground for long tubes to go in.
Also, if you ever intend to do polyurethane motor mounts, it will be mcuh easier with the headers out of the way. It is still a difficult job, though. I changed them on my 99 Z-28 and the stock mounts were totally trashed.
Old Dec 12, 2007 | 11:21 AM
  #32
i think i am going to keep the stock mounts for now.
Old Dec 12, 2007 | 11:26 AM
  #33
Depending on mileage, your stock mounts should be fine. My friend's 02 when he had it had ~45k miles and his QTP **** never banged once. My car had 100k at the time of the install and **** was banging like hell.
-J
Old Dec 12, 2007 | 11:34 AM
  #34
radz282003's Avatar
IMHO, get that car really high. MAKE SURE TO SAFELY SUPPORT THE CAR ON JACK STANDS!!! An SUV jack may be helpful in getting the car high enough. A 10mm gear wrench will be your best friend. Spray penetrent on all the manifold and Y-pipe bolts/studs/nuts. Take your time running the bolts back into the heads and use anti-seize. Get a dyno tune.
I think you'll feel a difference and probably pick-up a good 20+ RWHP. You'll love the sound!
Have fun!!!
Old Dec 12, 2007 | 11:36 AM
  #35
I cant wait to hear the difference compared to the flowmaster i have on my car now.
Old Dec 12, 2007 | 11:39 AM
  #36
radz282003's Avatar
I think you'll fall in love with the new sound.
Old Dec 12, 2007 | 11:41 AM
  #37
Yeah. My exhaust on the car now sounds like a stock catback. EVen though its broke in a bit. i am ready to hear the duals because i have never heard a set in person on a car that doesnt have a cam in it.
Old Dec 16, 2007 | 09:31 AM
  #38
Well...just finished installing the headers yeasterday. They were a pain in the *** to install but definitly worth it in the end. I did the MSD/NGK at the same time as my headers also. I am going to get the duals welded up and the car tuned come monday. I will post a sound clip as soon as i get the duals installed.
