Best pulley kit to get?
Old Jun 25, 2003 | 07:10 AM
WS6snake-eater's Avatar
Default Best pulley kit to get?
Hey I have been doing some searching, and I'm trying to figure out who has the best pulley kit. What is everyones feelings, on the different kits that are out there? Who's is the cheapest, and who's is the best? Does anyone have a review they would care to share?
Old Jun 25, 2003 | 02:42 PM
Cal's Avatar
Cal
Default Re: Best pulley kit to get?
The ASP pulley seems to be the most popular by far. I ordered one because it has a 25% reduction while many others are only 15% or 20%.
Old Jun 25, 2003 | 11:26 PM
2001CamaroGuy's Avatar
I like my ASP pulley.
Make sure you get the overdrive for the alternator. This will bring it back up to factory speed and prevent charging problems.
Old Jun 26, 2003 | 08:39 AM
ok great...does any of the sponsors offer the ASP pullies as a kit, with the crank pulley, alternator pulley and the belt?
Old Jun 26, 2003 | 08:49 AM
DarkLordFtT's Avatar
you may want to get a "Larry Pully" from asp also. It replaces your tensioner pully with A higher lip on it to prevent the belt from slipping off. Some people have had this problem.
Old Jun 26, 2003 | 09:48 AM
smokeyalater's Avatar
whats teh overdrive for the alternator??
Old Jun 26, 2003 | 10:01 AM
Cal's Avatar
Cal
It's a smaller than stock pulley that will bring the alternator back up to stock rpm so your battery won't go dead. If you have a M6 and don't lug the engine below 1500rpm I doubt you will need it.
