Headers goin' on, what do to while the manifolds are off?
Old Dec 13, 2007 | 07:20 AM
sixpack_2_go's Avatar
Originally Posted by fortmyerspolice
is there alot more vibration to the car with poly mounts?? this is my DD
yes, it will shake more. me and two of my friends have them in our 4th gen ls1 camaros, and love them
Old Dec 13, 2007 | 03:56 PM
Masochist's Avatar
Originally Posted by teke184
"If the motor mounts are poly, but everything else is rubber(tranny/suspension), will that create a problem?"
don't see why it would. why would having less flex on the part of the car that creates the flexing action, create problems with the rest of the drivetrain.
if nothing else it would help.
That is what I want to hear.
Now excuse me for asking a stupid question.
These Prothane motor mounts come in pairs, do they not?(referring to Thunder Racing) How many are there in total on our engines? Just two? Or do I need to buy more than one set?
Old Dec 14, 2007 | 07:16 AM
teke184's Avatar
there are only 2
should come in pairs...i think....should say on the listing.
you'll have to pull the stockers off the car. grind off some rivits i think, then use supplied hardware to bolt the poly ones on.
reinstall
have a jack under the engine (obviosly need it to support it) but jack up the motor a bit and it will make removal easier.
oh and do one side at a time. dont remove the other mount bolt till you finish the first side.. that way it will keep everything lined up for the most part. otherwise you'll be under there pushing and pulling the motor to get 2 bolts lined up.
Old Dec 15, 2007 | 05:36 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
You just don't want to mix solid and poly mounts. I have solid motor mounts and stock trans mount. No problems. And is a solid ride!
Old Dec 15, 2007 | 07:47 AM
bryan04h's Avatar
alright so i have a motor mounts on the way, am i going to feel any stiffness from this or is it just going to be there to help?
Old Dec 15, 2007 | 08:55 AM
PatrickF's Avatar
Why is this? I have a poly trans mount and I've been wanting solid motor mounts...
Anyone have solid mounts on a DD/street vehicle. Doesn't necessarily have to be a DD, but driven atleast twice a week on the street or something of the sorts.....
Old Dec 15, 2007 | 11:59 AM
JZ28's Avatar
I have solid motor mounts on my daily driver, actually it is my only vehicle and love them. Yes, they put a little extra vibration in the car, but its not much at all. Glad I did them. Probably only added 20 extra minutes to my long tube install.
Old Dec 15, 2007 | 12:42 PM
socmguy's Avatar
Restricted User
I installed my motor mounts while I did my rod bolt install. Here's a link to the thread:
https://ls1tech.com/forums/showthrea...s+prothane+rod
I have a cam so I definitely noticed a difference. The whole car shakes a little when I'm stopped at a light and when I rev, the whole car tweaks a little. LOVE 'EM!
Old Dec 15, 2007 | 01:05 PM
BadgeZ28's Avatar
Any advice on how to remove the stock manifold bolts without breaking one or more off in the head?
Old Dec 15, 2007 | 01:50 PM
bryan04h's Avatar
i used pb blaster on mine, but i don't think that is what the thread is about
Old Dec 15, 2007 | 08:25 PM
DarkJuggalo's Avatar
thats what im most scared about is snapping a bolt in the head lmao! i did it on my 3rd gen and was really pissed but again its a 5-6 yr old car vs a 20-21 yr old car ;D
Old Dec 16, 2007 | 09:28 AM
  #32
RareBreed0295's Avatar
Well i just finished up my Kooks LT install this weekend and had no clearance problems with the stock mounts. Maybe i was just lucky.
