Flowmaster, the worst possible choice?
Old Dec 12, 2007 | 04:44 PM
dutinsss's Avatar
do the single chambers when used on a true dual set-up restrict flow as badly as the 40 or 80 series with a y-pipe?
Old Dec 12, 2007 | 04:49 PM
TheSilverOne's Avatar
nope not even close
Old Dec 12, 2007 | 07:32 PM
Masochist's Avatar
So, is there any way to keep the Flowmaster pipes but change the Muffler out? Perhaps putting a straight pipe through, or a glass pack? Any ideas at all?? I do not want tobuy another cat-back!!!
Old Dec 12, 2007 | 11:10 PM
RevGTO's Avatar
Pontiacerator
You could fit a Hooker in there - a friend of mine did it. You have to cut the flange off the inlet on the Hooker, maybe use a little pipe to connect, and weld it up. IIRC, you have to do some work on the tailpipes too, but it's not too bad. A competent exhaust shop should be able to get it done inexpensively.
