Should I.....
Old Jun 25, 2003 | 10:53 PM
BLUEBYU's Avatar
Default Should I.....
..change out my GMAF for a SLP 85mm maf?...what is the size of the GMAF anywho? Was on the car when I got it. I am not seeing the air flow that it should be..H/C should be 40+ lb/sec and I am seeing 38ish ...let me know your thoughts..
Thanks.
Old Jun 26, 2003 | 08:06 AM
BLUEBYU's Avatar
Default Re: Should I.....
Will I see any air intake gains if I swap?
Old Jun 26, 2003 | 01:14 PM
BLUEBYU's Avatar
Come on folks...there has to be some experts on this....
Old Jun 26, 2003 | 03:47 PM
BLUEBYU's Avatar
Old Jun 26, 2003 | 03:50 PM
Cal's Avatar
Cal
I say stay with the stock MAF; it will flow enough to support 400 hp. If you change to one of the others you will will have to be good with LS1edit to get it working right because the MAF tables in the PCM will need to be modified. Also, your engine will only get so much air anyway because the stock Throttle Body is a bottle-neck.
