cant remove power steering wheel.. pls help!
Old Dec 14, 2007 | 12:39 PM
VtecDis's Avatar
Exclamation cant remove power steering wheel.. pls help!
im currently in the process as i type this of replacing my power steering pump and reservoir. but i cant figure out how to get the balancer or wheel or what ever its called off??? can anyone pls help! ive tired searching with no luck
Old Dec 14, 2007 | 01:39 PM
00ssmg's Avatar
Default Power Steering Pulley Pulller
You Need To Go And Rent A Power Steering Pulley Puller From Autozone Or Murrys Something Like That.....be Carefull Not To Crack Pulley...you Will Also Need An Installer....if Cant Get That You Can Use Nut And Bolt Along With Some Washers...
Old Dec 14, 2007 | 01:53 PM
VtecDis's Avatar
oh. i thought the pully was the belt lol., **** thanks man.
Old Dec 14, 2007 | 01:55 PM
Undertow74's Avatar
Yea to get the pulley off you need the puller.....its got 2 pieces that look like half moon's with a retaining ring that goes around it, and then there is a stud that you just screw in and it pullls they pulley right off. just make sure its seated under the lip on the pulley all the way that pot aluminum **** cracks really easy. the installer is almost the same thing, the stud just has a bigger surface on the bottom to help push it back on. hope ya can find one!!
Old Dec 14, 2007 | 02:00 PM
1970judge's Avatar
Local autostore should have a power steering pulley puller.
Old Dec 14, 2007 | 02:13 PM
VtecDis's Avatar
ok sweet. thanks for all the help
