can i run these heads?
Old Dec 17, 2007 | 10:13 PM
408Maro's Avatar
Default can i run these heads?
hey all i want to get the ms4 cam from tsp with there ls6 stg1 heads but noticed theres not a big price diff. to get there sgt 2.5 heads only diff is the stg1 is 2.00 I/1.55E and the 2.5 is 2.02I/1.57E. would i have to have anything done to run the sgt 2.5's with my stock internals? thanks
Old Dec 17, 2007 | 11:16 PM
chuckyt1's Avatar
I don't know about the MS4 but, I run the PRC heads with 2.02 valves and a T Rex cam. I measured the ptv and decided to flycut. Could not be happier... Flycut if you need to, raise the compresion and have some fun...
Old Dec 18, 2007 | 11:52 AM
GMmexican's Avatar
call Texas speed foo
Old Dec 18, 2007 | 02:05 PM
jmm98LS1's Avatar
As you increase valve size, the probability that you'll need to flycut your pistons goes up.
Old Dec 18, 2007 | 02:34 PM
Asmodeus's Avatar
You'll need to flycut with valves any bigger than stock with an MS4. In fact, to get a "safe" clearance on an MS4, you should probably even flycut with stock heads.
