long tube install
Old Dec 27, 2007 | 04:45 PM
RedTtop6spd's Avatar
4 hours by myself with front up on 2 jackstands. Used a cutoff wheel to separate manifolds from y-pipe as I didn't care about the stock setup anymore and didn't want to mess with those bolts. Cut two bolts after cat on driver's side and cut the pipe just ahead of cat on passenger's side. Dropped the old manifolds out easily. Sparkplugs were already out. Didn't remove anything else. Slid right up in and then supported them on an old box while I threaded bolts in from the top. Hooker stainless competitions.
Old Dec 27, 2007 | 04:49 PM
BANDIT8's Avatar
any detailed pics
Old Dec 28, 2007 | 09:48 PM
Unfortunately no pics. For the driver's side, to get the old you're going to move it towards the rear of the car as you rotate it downward until the flange is 90 degrees from where it started, basically the flange straight up and down. Then it drops straight down from there. Putting the new header in is exactly opposite. Start with the flange straight up and down near the back of the engine as you slide it up in, then when the top of the flange gets to the exhaust port on the cylinder head, rotate the collector up as you move the header forward in the car.
Basically you keep the number 1 tube on the manifold / header in line with each of the exhaust ports on the head as it moves out / in.
You just need to get the car up high enough that you can stand the header on the end of the collector under the car right next to the oil filter.
Trying to explain it best I can so that you can possibly visualize it, but yeah, hard without pics, sorry.
