Question about PCV line for the FAST TB
Old Dec 24, 2007 | 06:46 PM
Hardtop00SS's Avatar
Default Question about PCV line for the FAST TB
I got a used FAST 90MM throttle body and had a question about the PCV line that runs from the passenger valve cover to the TB, the FAST doesn't have a hookup for it, what do I do about it? Just cap the nipple on the valve cover and let it go? I have the stock PCV system with a catch can. I searched and couldn't get much help.
Thanks
Old Dec 26, 2007 | 06:21 AM
guess nobody has ever ran into this problem?
Old Dec 26, 2007 | 10:54 AM
405HP_Z06's Avatar
Yes they have, I see more questions about this from Corvette guys. Your options:
1. Make the PCV system non functional and put a small breather on this line (Not a good option in my opinion)
2. Put a nipple in the air bridge or transition hose and run it to there, see the following thread: http://forums.corvetteforum.com/show....php?t=1894968
Don't put this hose in front of the mass air meter or you will ruin it.
Old Dec 26, 2007 | 05:18 PM
So put a nipple in the bellow and run it like that? Howcome you just can't put a cap on the fitting on the valve cover a let it go? Or maybe put a t fitting in the hose that connects to the side of the intake?
Old Dec 27, 2007 | 03:06 AM
405HP_Z06's Avatar
Because this is the line that supplies fresh air for the PCV system. To cap it off, you would need to delete your PCV system and run a breather on the crankcase.
Old Dec 27, 2007 | 05:58 AM
oooohhhh, I understand now
They said you can get a small filter to run from an autoparts store, what kind of filter is it?
Old Dec 27, 2007 | 11:18 AM
405HP_Z06's Avatar
A small inline filter.
