Edelbrock Headers
Old Dec 31, 2007 | 08:00 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Exclamation
Originally Posted by Asmodeus
Also, ceramic coated headers will make less power because they lock heat in the exhaust. This tends to cause detonation and the car can't take as much ignition timing.
100 % INCORRECT.
Old Dec 31, 2007 | 08:01 PM
NHRAMAN's Avatar
Thumbs down
More exhaust pressure does not equal more power. Quit being brainwashed. The only area where this even helps is a turbo application, for faster spool. Velocity without more flow = resistance. You have less gas taking up more space in the same confined non-changing area. You are causing resistance in the primaries. That heat is going to back up. In a turbo application, you don't have to worry about it because you have such a high positive manifold pressure. To answer your question, YES I would rather have the heat dissapate into my engine bay through non-coated stainless headers.
NOPE. For gods sake..please talk to KOOKS,SLP,QTP,EDELBROCK..ETC...
Old Jan 1, 2008 | 04:14 AM
Asmodeus's Avatar
What do I know anyways right? I guess this will just be a topic of debate. Ask Eric at HPE what he thinks he'll say one thing, ask someone else, they say another, and chances are both have dyno'd a lot of cars. I'm siding with Eric on this one because his theories make sense, and he has seen ceramic coated headers make less power on the dyno, I pulled most of my examples from his words.
I would NEVER run ceramic coated in an NA application, PERIOD.. but I guess that's just me.
We can argue about this, but I've given reasons why I believe ceramic coated is bad, and all anyone else has said is I'm wrong, without saying why. Why is that? fooled by the masses? no thoughts of your own?
Old Jan 1, 2008 | 05:31 PM
INMY01TA's Avatar
100 % INCORRECT.
Agreed.
Old Jan 1, 2008 | 06:23 PM
ChocoTaco369's Avatar
Tech Resident
Ceramic coated headers don't make less power because they hold in heat... That's the only positive they have going for them. Ceramic coated headers usually make less power because they're typically made cheaply and the design is therefore not good. The companies with stainless headers - Kooks, QTP, ARH - they make more power because they have more R&D dumped into the design. They're also typically longer. My QTP's are super-long. I believe they're the longest LT on the market AND are equal length (which is why they are usually a tad trickier to install), plus they have awesome collectors, so you can't compare them to a Pacesetter. They'll make a lot more power in every case...but not because Pacesetters hold in more heat.
